I just purchased the G34 and it seems to be limited to 31 devices (based on debugging problems on my network). How many devices are supported? This critical information is not provided on the Arris website or in any documentation that I have found. What modem/routers support more than 31 devices?
Maximum Devices to connect on Wi-Fi network with G34
On G34 is supported to connected more than 200 devices so you can try connecting to the network 2.4 or 5G according to the device compatibility
