Is there a setting that must be enabled to provide normal speeds through the 2.5g port? I’m unable to connect to the internet via the 2.5g port on the back of my G36 with more than minimal (under 1mbps) speeds.
I have Xfinity Gigabit (1.2Gbps) and with the 1g ports I can routinely get ~1Gbps with a wired connection.
When I plug the same patch cable (both Cat5e and Cat6) into the 2.5g port, there is no signal to my office 4-port switch, and almost no connection speed to my laptop 4ft. away from the gateway.
Am I wrong in thinking that 2.5g port should operate the same, and better, than the other four ports?
