Band Steering
  • May 20, 2022
  • 58 views
Where the Wild Pings Are
Cable Modem Commandos
Forum|alt.badge.img+9
Does the mAX use band steering?
Best answer by dan_w
Yes, the SURFboard mAX supports band steering.  It can be enabled using the SURFboard Central mobile app.  Click on Network towards the bottom of the screen, then select Extended Wi-Fi Settings to enable the feature.
  • Button Mashers
  • 9 replies
  • May 27, 2022
