This is my second S33, the first one died after about 8 months of use. I have my household running off this modem with a set of (3) Arris AX 11000 routers. It seems every time I sit down at the computer which is actually plugged into the router the S33 will reset. This will happen frequently but ONLY when the computer is on and connected to the router. Today it has reset twice. I can shut down the computer and go weeks, even months without a problem. Then turn on the computer and within an hour or so the S33 will reset.
