Comparison between S34 and S33
  • August 27, 2024
  • 15782 views
Whats the difference between the S34 and S33?
The only difference is the S34 supports fast upload speed for Xfinity Next Gen speed plan. Other than that all specification are same on for both S33 and S34.
