Network ARRIS site 192.168.0.1 ERROR- won't pull up
  • November 10, 2024
  • 85 views
Network ARRIS site 192.168.0.1 ERROR- won't pull up. -I’ve tried numerous browsers, rebooted, also tried 192.168.0.1.1 - won’t connect. I need to update settings- Please help! My router model #: W31- //Modem model: S33v2.
The w31 doesn’t have a browser based gui. Its app only.
And the modem side would be at 192.168.100.1
  • 2287 replies
  • November 10, 2024
  • November 10, 2024
Thank you!!
  • 2287 replies
  • November 10, 2024
good luck! let us know if you have issues
  • November 10, 2024
Appreciate that. I did get the app. Once in there it says I have low speed. My ISP is Comcast & have 1000mb high speed (supposedly) I read the several ways to improve speed but my desktop is hard wired, ethernet- so router & modem has to be connected to that. In other words, I can't move them any where. The room they're in does have clear path (basically). I unplugged router & modem & reconnected. That didn't do anything. I read might need to reset factory settings.
My question is, will that throw all my setting off with Comcast or any of my other settings, etc.?
Thx for help, if you have time.
