Modem Help SB8200
  • October 19, 2022
  • 6 replies
  • 1057 views
So my original problem was that my internet connection was dropping (Xfinity) so we scheduled a tech to come out for a fix.
The initial issue was resolved because it turned out that the line was damaged and the house we moved into had multiple splitters that were causing our signal to "leak" he mentioned that he was surprised that we had a connection at all from how bad it was, he disabled all the other Coax outlets that weren't in use and our issues were fixed for that day.
I should note that Prior to this visit we had our Arris SB8200 modem's lights as Blue for downstream. (speeds are 600+mbs Down and 30mbs Up)
After his visit the internet went down that night only to return in the morning but the lights on the Modem turned all Green and occasionally flicker (and have remained green) but occasionally it turns Blue for downstream for about 5-10 seconds whilst the connection drops only to return to green again.
For ex. any stream/Netflix video/Game that is running will cut out for that time while the downstream light turns Blue but reconnect once the lights turn back green. Our speeds are still as fast as before but the connection is not consistent at all.
We Power cycled the modem repeatedly asked Xfinity to reset our connection on their end, Factory Reset our modem and even called the tech back to check it out, but He couldn't figure out why this was happening and every time we tried asking for Xfinity to help they kept trying to sell us their modem and upgrading our plan instead of doing anything else.
I am not a techie that can diagnose the issues from the modems login page so I can't tell what is going on there.
What are my options to fix? could it be a Modem issue? a Coaxial Cable issue? Power issue?
(edit: CM-MAC information removed)
Date Time Event ID Event Level Description
10/19/2022 01:09 74010100 6 "CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:09 74010100 6 "CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:09 74010100 6 "CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:08 74010100 6 "CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:08 74010100 6 "CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:08 74010100 6 "CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:08 74010100 6 "CM-STATUS message sent. Event Type Code: 20; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:07 74010100 6 "CM-STATUS message sent. Event Type Code: 20; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:07 74010100 6 "CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:07 74010100 6 "CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:07 74010100 6 "CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:06 74010100 6 "CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:06 74010100 6 "CM-STATUS message sent. Event Type Code: 20; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:06 74010100 6 "CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:05 74010100 6 "CM-STATUS message sent. Event Type Code: 20; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:05 74010100 6 "CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:05 74010100 6 "CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:05 74010100 6 "CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:04 74010100 6 "CM-STATUS message sent. Event Type Code: 20; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:04 74010100 6 "CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:04 74010100 6 "CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:04 74010100 6 "CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:03 74010100 6 "CM-STATUS message sent. Event Type Code: 20; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:03 74010100 6 "CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:03 74010100 6 "CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:03 74010100 6 "CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:02 74010100 6 "CM-STATUS message s
Acquire Downstream Channel 675000000 Hz Locked
Boot State OK Operational
Configuration File OK
Security Enabled BPI+
Downstream Bonded Channels
44 Locked QAM256 675000000 Hz 3.6 dBmV 42.8 dB 0 0
13 Locked QAM256 489000000 Hz 3.5 dBmV 43.7 dB 0 0
14 Locked QAM256 495000000 Hz 3.5 dBmV 43.6 dB 0 0
15 Locked QAM256 501000000 Hz 3.5 dBmV 43.7 dB 0 0
16 Locked QAM256 507000000 Hz 3.7 dBmV 43.7 dB 1 0
17 Locked QAM256 513000000 Hz 3.7 dBmV 43.8 dB 0 0
18 Locked QAM256 519000000 Hz 3.7 dBmV 43.8 dB 0 0
19 Locked QAM256 525000000 Hz 3.6 dBmV 43.7 dB 0 0
20 Locked QAM256 531000000 Hz 3.3 dBmV 43.6 dB 0 0
21 Locked QAM256 537000000 Hz 3.2 dBmV 43.7 dB 0 0
22 Locked QAM256 543000000 Hz 3.1 dBmV 43.5 dB 0 0
23 Locked QAM256 549000000 Hz 3.2 dBmV 43.6 dB 1 0
24 Locked QAM256 555000000 Hz 3.2 dBmV 43.6 dB 1 0
25 Locked QAM256 561000000 Hz 3.3 dBmV 43.6 dB 0 0
26 Locked QAM256 567000000 Hz 3.2 dBmV 43.7 dB 0 0
27 Locked QAM256 573000000 Hz 3.1 dBmV 43.6 dB 0 0
28 Locked QAM256 579000000 Hz 3.2 dBmV 43.5 dB 1 0
29 Locked QAM256 585000000 Hz 3.4 dBmV 43.7 dB 0 0
30 Locked QAM256 591000000 Hz 3.7 dBmV 43.8 dB 1 0
31 Locked QAM256 597000000 Hz 3.9 dBmV 43.7 dB 0 0
32 Locked QAM256 603000000 Hz 4.0 dBmV 43.9 dB 0 0
33 Locked QAM256 609000000 Hz 3.9 dBmV 43.8 dB 2 0
34 Locked QAM256 615000000 Hz 3.7 dBmV 43.7 dB 1 0
35 Locked QAM256 621000000 Hz 3.6 dBmV 43.7 dB 0 0
36 Locked QAM256 627000000 Hz 3.5 dBmV 43.6 dB 1 0
37 Locked QAM256 633000000 Hz 3.6 dBmV 43.7 dB 1 0
38 Locked QAM256 639000000 Hz 3.7 dBmV 43.6 dB 0 0
39 Locked QAM256 645000000 Hz 3.7 dBmV 43.7 dB 0 0
40 Locked QAM256 651000000 Hz 3.6 dBmV 43.5 dB 0 0
41 Locked QAM256 657000000 Hz 3.5 dBmV 43.5 dB 0 0
42 Locked QAM256 663000000 Hz 3.5 dBmV 43.6 dB 0 0
43 Locked QAM256 669000000 Hz 3.5 dBmV 43.6 dB 0 0
193 Locked Other 957000000 Hz -2.7 dBmV 35.0 dB 50156001 0
Upstream Bonded Channels
Channel Channel ID Lock Status US Channel Type Frequency Width Power
1 17 Locked SC-QAM Upstream 16400000 Hz 6400000 Hz 42.0 dBmV
2 18 Locked SC-QAM Upstream 22800000 Hz 6400000 Hz 42.0 dBmV
3 19 Locked SC-QAM Upstream 29200000 Hz 6400000 Hz 42.0 dBmV
4 20 Locked SC-QAM Upstream 35600000 Hz 6400000 Hz
43.0 dBmV
Hello H.TheMan,
The issue that I found is with the upstream power levels, since they should be between 45 dBmV to 51 dBmV and yours are below the accepted range. Your ISP can adjust them and that’ll fix the issue. I will attach an article that will have the complete information. Hope this helps you.
https://arris.secure.force.com/consumers/articles/General_FAQs/SB8200-Cable-Signal-Levels/?l=en_US&fs=RelatedArticle
  • October 19, 2022
44 Locked QAM256 675000000 Hz 3.6 dBmV 42.5 dB 0 0
14 Locked QAM256 495000000 Hz 3.5 dBmV 43.8 dB 0 0
16 Locked QAM256 507000000 Hz 3.7 dBmV 43.8 dB 0 0
17 Locked QAM256 513000000 Hz 3.7 dBmV 43.7 dB 1 0
20 Locked QAM256 531000000 Hz 3.4 dBmV 43.7 dB 0 0
21 Locked QAM256 537000000 Hz 3.2 dBmV 43.5 dB 0 0
22 Locked QAM256 543000000 Hz 3.1 dBmV 43.6 dB 0 0
23 Locked QAM256 549000000 Hz 3.2 dBmV 43.5 dB 0 0
24 Locked QAM256 555000000 Hz 3.2 dBmV 43.4 dB 0 0
25 Locked QAM256 561000000 Hz 3.3 dBmV 43.7 dB 0 0
26 Locked QAM256 567000000 Hz 3.2 dBmV 43.4 dB 0 0
27 Locked QAM256 573000000 Hz 3.1 dBmV 43.4 dB 0 0
28 Locked QAM256 579000000 Hz 3.2 dBmV 43.5 dB 0 0
30 Locked QAM256 591000000 Hz 3.7 dBmV 43.7 dB 0 0
31 Locked QAM256 597000000 Hz 3.9 dBmV 43.8 dB 0 0
32 Locked QAM256 603000000 Hz 4.0 dBmV 43.8 dB 0 0
33 Locked QAM256 609000000 Hz 3.9 dBmV 43.8 dB 1 0
34 Locked QAM256 615000000 Hz 3.7 dBmV 43.6 dB 0 0
35 Locked QAM256 621000000 Hz 3.6 dBmV 43.8 dB 2 0
36 Locked QAM256 627000000 Hz 3.5 dBmV 43.5 dB 0 0
37 Locked QAM256 633000000 Hz 3.6 dBmV 43.6 dB 1 0
38 Locked QAM256 639000000 Hz 3.7 dBmV 43.8 dB 0 0
39 Locked QAM256 645000000 Hz 3.7 dBmV 43.6 dB 0 0
40 Locked QAM256 651000000 Hz 3.6 dBmV 43.6 dB 0 0
41 Locked QAM256 657000000 Hz 3.5 dBmV 43.4 dB 0 0
43 Locked QAM256 669000000 Hz 3.6 dBmV 43.5 dB 0 0
193 Locked Other 957000000 Hz -2.7 dBmV 34.8 dB 15975031 0
  • October 19, 2022
it just flickered Blue again and this was the Event Log messages
10/19/2022 01:42 74010100 6 "CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:42 74010100 6 "CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:41 74010100 6 "CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:41 74010100 6 "CM-STATUS message sent. Event Type Code: 1; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:41 84020300 5 "MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:41 85000200 3 "UCD invalid or channel unusable;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
10/19/2022 01:41 67061600 6 "DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:90:f0:1f:00:00;CM-QOS=1.1;CM-VER=3.1;"
  • 2275 replies
  • October 19, 2022
Your error codes are still indicating some line issues with the connection. Your power levels aren’t bad but something is still causing interference.
  • October 19, 2022
Could the interference come from the outlets being worked on?
the tech mentioned that he had to replace a line outside because of some damage but this issue never happened before even with the damaged line.
Should i move my modem to a different room? or Is there anything i can provide for the tech to make this issue easier to diagnose.
Hello H.TheMan,
  • 2275 replies
  • November 1, 2022
the power levels are fine. Its just something with the connection that the ISP will probably need to come check again.
When the downstream power levels are higher it indicates either your using an amplifier or you’re close to the hub. Based on your upstream, you’re close to the hub or the upstream levels would be higher.  The upstream is the modem sending a signal back to the cmts/hub. If its further away or there’s something reducing the signal (like a splitter/attenuator) the modem will have higher upstream levels to be “talk” to the hub/cmts.
