Should the RECEIVE led light ideally always be blue or is it normal to sometimes be green?
Should the RECEIVE led light ideally always be blue or is it normal to sometimes be green? Sometimes it changes to green meaning it’s in DOCSIS 3.0, and stays there until i power cycle the modem. Is this less than ideal? Does this indicate a problem with the coaxial line
Tends to indicate an issue. If you have docsis 3.1 in your area, it should be blue. It only drops to green when the docsis 3.1 goes down and it reverts to docsis 3.0.
Do you have a screen snip of the cable connections page and event logs?
  • 2287 replies
  • January 4, 2023
  • January 5, 2023
I failed to mention I had my coax cable hooked up to a surge protector on a power strip. I'm going to bypass that and hook up straight to my modem and see how it goes. I think the surge protector is causing the issue.
  • January 7, 2023
Sorry. I failed to mention that I had my coax hooked up to a surge protector. I removed that and it’s straight to the modem now and the RECEIVE led is staying blue now. The surge protector was causing the issue.
  • 2287 replies
  • January 7, 2023
Glad it was something simple! Hope it stays working well for you
  • January 20, 2023
A follow up question -  What would cause docsis 3.1 to go down?  Is this due to a problem originating from the ISP?  A few days ago the RECEIVE light on my SB8200 periodically started changing from blue to green and back again.  Yesterday it stayed green until I turned the modem on/off.  Now it is blue again. Speed is still the same either way.
  • 2287 replies
  • January 21, 2023
Many things can cause it to drop between the 2.
Tends to be (again) be line issues causing problems.
but tough to diagnose without the cable connections page and event logs. Those help check the line.
