Arris HEVC Cable Box - can use 2 remotes?
  • January 31, 2023
  • 123 views
Hi. I’ve got an Arris HEVC 4K Ultra HD cable streaming box, and a branded remote from my cable provider with their logo and a Netflix button on it. This remote is connected via Bluetooth. I got a 2nd remote, also branded from my cable provider. Can I have 2 remotes connected by Bluetooth that both work? The pairing instructions only seem to work for the first one. Thanks!
most devices only support 1 bluetooth device connected at a time. I wouldn’t be surprised if this was the same.
  • 2287 replies
  • January 31, 2023
