I’d welcome any insight as to what may cause the 5GHz WiFi signal on the G36 to regularly provide slower (19, 27, 35 40, 65mbps, etc.) network speed than the 2.4GHz (72mbps). 2 Coax cable connected devices meet network speed service levels (Network is WOW, Service Level is 300/20.) Only two devices connected to 5GHz channel (1 Android phone, 1 Tp-Link Mesh WiFi Extender.) Other factors for consideration:
- Both frequencies are using non-congested channels in my area (they are the only signal on their respective channels according to the WiFi Spectrum analyzer.)
- Bandwidth selection set to Manual: 2.4Ghz is 20/40; 5GHz is20/40/80
- Default settings for MU-MIMO enabled; DFS disabled
- Distance from the modem/router does not change these results (10 inches up to 50 feet.)
- Rebooting the modem/router does not change these results.
I’m unsure of any other potential signal interference to consider. I’m unsure if this issue is a product Warranty Issue. I did achieve 433mbps speeds when I first installed the G36, but that was about 1 month ago. (Could a Factory Reset vs modem reboot correct some hidden signal restriction or interference?)
In any event thank you in advance for your time and consideration regarding this matter.
Larry G
