Hello. I just recently move over to my own hardware from Xfinity. I have a S33 Modem and a W21 Router. I recently upgraded my internet speed as well to 1.2gb. If I run a speed test at the modem I can usually get 1Gb for download. However over WiFi or connecting directly into the w21 with a cable I can only get about 100mb download. I have factory reset the W21 and when I did that I was about to get 900mb on download. 8 hours later it was back at 90mb for download. I’ve been digging through the app trying to find a setting that might be causing it but I can’t find anything. I’ve restarted both router and modem since then and seen no increase of speed. I will say if the router is connected to the 2.5gb port and I connect my computer right into the 1Gb on the s33 I am unable to connect to the modem. However if I restart the modem with my computer connected I will be able to access it when it comes back up.
