intermittent internet connection on S33
  • 9 April 2024
  • 119 views
I purchased an Arris S33v2 last November. We have been having at least 2 to 3 short dropouts daily. We thought it might be a cable issue as the upstream voltage was a little high and downstream was a little low. (Also saw some UCD invalid or channel unusable messages in the event log)
Ran a new RG6 Quad coax directly from the outside cable box to the modem. The voltages fell within the normal range but the daily reboots continued.
The Xfinity tech recommended getting a different modem. I already had my old SB8200 so I installed it. It has been up several days now with zero dropouts.
How do I go about getting a warranty replacement?
Best answer by SURFboard Moderator 11 April 2024, 02:24
In this case if your modem is under warranty you can reach out to Arris.co/consumersupport so you canĀ get connected to our phone support team to proceed further.
