What is the product runtime on sbg6950ac2 Gateway
  • 11 April 2024
  • 14 views
it set on 10 hours and 00 minutes. Not sure if its a timer or what it is
Best answer by SURFboard Moderator 16 April 2024, 01:03
Are you referring to the modem GUI page where it will ask you to set the Time of your location on the initial setup of your modem?
its in the modem GUI page under utilities and product run time
Product Runtime is only for factory use. There is no impact on operability.
