So I’m at a loss….. I’m trying to locate the DTMI settings on the admin page for the Arris G54. But I’m not finding them anywhere. Am I just completely overlooking it?!
thanks
View originalSo I’m at a loss….. I’m trying to locate the DTMI settings on the admin page for the Arris G54. But I’m not finding them anywhere. Am I just completely overlooking it?!
thanks
View originalSorry. DTIM settings.
I regret to inform you that the DTIM settings are not available on the Arris modem/gateway.
Is there a plan to enable this and is there a place to see what the current default value is?
There is no option to check the current default value for DTIM.
