My Roku express+ and Surfboard G36 disconnect daily. I have to do a system restart on the Roku to connect to the G36 and this is becoming troublesome.
I’m able to connect the Roku to the G36 successfully, however, randomly they stop communicating. I asked Roku if it was the Roku device and they said no. because the Roku works correctly when I use my iPhone 15 hotspot.
Looking around some suggested I make sure the G36 is set up on “b/g/n” and it is in fact set up on “b/g/n/ax” for 2.4 GHz.
The issue has to be with the G36. It’s new as of December 2023 and that when this issue started.
Any thoughts on a solution?
Best answer by allisonrja
