DG 3450 using with MO CA - how to connect
  • 18 July 2023
  • 16 views
We have ONLY internet through our cable provider, hooked up with the ARRIS DG 3450 wifi-modem. It says that it’s MO CA 2.0 channel bonding enabled. I want to extend wired internet to another room with two coax jacks. With the modem being enabled for MO CA 2.0, how are the MO CA adapters to be hooked up? I cannot find anything on youtube that addresses this and our internet provider will NOT provide any sort of advice at all.
Thanks!
Well I found out that if you have a Mo Ca enabled router/wifi, all you need to do is hook up the adapter to your coax jack and the ethernet cord that comes with it to the device you want hardwired, and it is supposed to work. You need to get into the router’s software, and ensure that the mo ca feature is enabled, and you don’t need to hook up the mo ca adapter to your router or the co ax jack it’s hooked to.
