Can I run ethernet cable from router down garden( in ducting) to summer house then plug in x5042 for improved WiFi? Please
View originalCan I run ethernet cable from router down garden( in ducting) to summer house then plug in x5042 for improved WiFi? Please
View originalThank you for the answer. Ducting-nothing technical just pipe work either solid, rigid or flexible to protect cable run.
Should be pretty solid then. I’ve connected a remote building that route (not same extender). It works well. If the ducting is underground, I’d make sure to install underground rated ethernet cable. Not much more expensive but worth it.
I will do that. I was not aware of types of cable rating other than Cat number. I cant wait to get started.
