Hello,
I have an S33 modem with Spectrum internet. The spectrum tech installed the modem and it has been hooked up to a wireless router and working fine with all wi-fi connections. After the install I connected the modem directly to a network switch and the wireless router still works fine. However I have connected an NVR home security system to the switch that requires direct ethernet and it wont connect. I called the security camera support and they are telling me that the direct line is IPV6 and it needs to be IPV4 to work. I am also experiencing no internet connection my wired Samsung smart tvs. Is there an easy fix?
