I am in need of some replacement power supplies for SB6190. I am seeking the best quality for the best price. Oem would be ideal.
Your best bet might be ebay or amazon.
Its rare to see direct power supplies sold. Usually you pick up 3rd party ones or OEM used versions.
You just need to make sure it has matching voltage and polarity. You can have higher amperage but not lower.
