SBG7600AC2 range
  • November 27, 2023
  • 67 views
Please tell me the best 2.4Ghz “Settings”  I should be using to provide the most increased range of my SBG7600AC2 Modem Router. I have a BLINK Camera network and the WIFI signal strength is very low on 2 of the five cameras. Thank you.
the strength isn’t going to change. That’s been maxed out on routers for a while.
You can try changing the channel its on to optimize for your area.
But if its a strength issue, you’d need to either add an extender or switch to a mesh system for more coverage
  • 2324 replies
  • November 27, 2023
