wifi speed coming from SBG8300 only 5 feet away getting 53mbps on 2.4ghz & 5ghz yet with ethernet hardwired to Orbi the wifi is 890mbps.
Wifi
Hello mordini .
We understand that you are getting wifi speed as 53mbps on your 2.4 ghz and 5 ghz .
Due to wifi congestion , we can change the wifi channels to access a good speed
Please follow the steps on the below mentioned link to change the wifi channels
Please let us know if this helps
If this is a new setup, make sure the SBG8300 is away from other electronic device or appliances which can cause Wi-Fi interference.
