G34 Compatibility with Cable America
  • 28 December 2023
  • 55 views
I currently have an older Arris model (SGB6580). I recently bought an Arris G34 modem/router. Unfortunately, I did not check with my internet provider to see if the G34 was compatible. I use CableAmerica. They informed me that it is currently in the works for the G34 to be compatible with them, but they were not able to give me a timeline. My question is if there is a known timeline for when the G34 model will be compatible with my provider? I am wanting to know if it is worth holding onto it or just getting a different one.
Best answer by SURFboard Moderator 29 December 2023, 23:05
Arris modem are compatible only with coax cable connections only not with ADSL or fiber cable connection so regarding compatibility you need to confirm with your service provider only.
