Just got done installing a new G34, and ran into an issue during configuration…
On the “Gateway > Connection > Wi-Fi > Networks” admin panel, I enabled Band Steering because I don’t want to hassle with multiple SSID’s. Tested a bunch of devices with this, and everything works fine.
Now, I also want to completely disable the two Secondary and two Guest Wi-Fi networks. However, when I do so Band Steering also returns to disabled status.
I thought to disable SSID broadcasting for each of them which would have been better than nothing, but Band Steering becomes disabled when that’s done as well.
Am I going about this wrong, or is what I’m trying to do impossible? I’m aware I could set the Secondary and Guest network passwords to some off-the-wall value to secure them, but that would only be a workaround and obviously not what I’m actually trying to accomplish.
Thanks in advance for any advice!
