I have a situation where I have had daily connection issues and had to do multiple hard resets. Now the unit will not reset. The way I know is because in the past when I do a 20 second reset the ethernet lights would turn orange. Now they won’t turn orange and will never connect.
BTW, I have an open support ticket on this. I think I have a bad unit and I’m trying to get a replacement but I have to do the support dance. I explained that if the connection light never turns blue, they will never be able to diagnose the issue remotely. Am I correct?
Best answer by AUser
