I live in a place with many WiFi access points around me. In order to get good connectivity, I set my 5G radio control to manual and select a free channel. It works well and i get good throughput. The problem is that even though the control is set to manual mode, every morning when i start working, I find that the radio has switch itself back to one of the very busy channels and i have to login a switch back. It seems that in “manual” mode, it lets you select a channel, but it still does an audit every day and overrides your selection. Also, the view the WiFi’s view of channel use is different from my computers view.
I would like to be able to force the router onto a specific channel and lock it.
