I have a new G34 and love it. However, it is on one end of the house and the signal strength is weak at the far end of the house. There is a Cat 7 ethernet cable running from the new G34 to the far end of the house, so is it possible to install a second G34 using the ethernet cable and create a Mesh network of sorts, to enable using the same WiFi SSID and seamless handoff? If so, what settings would be used on the host G34 and the satellite G34? Other suggestions?
