Losing higher speed Wi-Fi in G34
  • 9 December 2023
  • 48 views
Why does my higher speed wifi keep dropping off.  I have to reboot every few days to get it back.
Is there any wY to correct this issue?
Are you facing slow speed issue on direct connection or on WIFI connected devices?
If this is only on WIFI you can try changing WIFI channel to fix this issue, please follow the steps mentioned on the below article to change the WIFI channel and After changing WIFI channel as recommended on the link restart the modem then i would request you to monitor the connection for next 24hrs.
