I am trying to expand the single 2.5gb port on my G36 modem and not having any luck getting it
connected to any devices when going through a multi-gigabyte switch. I first tried the TP-Link
switch (TL-SG105-M2) which has five 2.5gb ports, and that did not work so i shipped it back and ordered the QNAP switch (QSW-2104-2S) and that did not connect either. It’s very basic troubleshooting, when any device is connected to the G36 2.5gb port directly there are no issues.
But if i connect the G36 2.5gb port to switch and then try to connect devices to that, they do not connect. Also, the 1gb ports on the G36 do not have an issue connecting to any devices either
directly or through the switch. The connectivity issue only occurs with the G36 2.5gb port going
through a multi-gb switch, such as the two i mentioned above.
Anyone else able to connect the G36 2.5gb port to a switch with 2.5gb ports, successfully?
QNAP has been great trying to help me troubleshoot but attempts to get Arris support involved
resulted in two hungup phone calls
