Internet no connection sbg6580
  • 7 November 2022
  • 181 views
Sbg6580 powers on but then the receive light just keeps flashing. I get a message that says “connected but no internet'
Best answer by plemans 8 November 2022, 16:02
Userlevel 6
Badge +40
do you have a screensnip of the cable connections page and event logs?
Thanks for the input. I had Spectrum come out and there was a whole bunch of problems. The main one was the cable for wifi had been weathered and it finally broke out at the roadside pole. I still have some problems with Spectrum.
