SBG6782-AC unable to locate printer in hardwired computer
  • 21 April 2023
  • 29 views
Does the privacy SBG6782-AC model have a “privacy separator” or “wifi isolation” feature?  I am trying to set up a wifi enabled printer, and it works great to print from phones also on wifi, however my PC running Win11 using a hardwire can’t find the printer.
Thanks
Userlevel 6
Badge +40
Is the compute set to use a private network or public network in windows?
did you contact the printer manufacturer for help setting up their device to print?
Public as this is my desktop in my home. My printer vendor says to insure router “privacy separator” is disabled in their set up instructions, so have not contacted them yet as I have not fully tried their printed instructions yet.
