S33 constant noise loud and irritating
  • 21 February 2024
  • 317 views
My S33 modem is working fine but makes a lot of noise - a constant fluttering/chirping/skipping sound. I’ve had it for about a year but recently moved it close to my desk where it’s driving me crazy. Is this normal? Are there other routers on the market that are quiet? I use Xfinity. Thanks.
Best answer by plemans 21 February 2024, 16:14
Userlevel 6
Badge +40
that for sure isn’t normal.
Is it coming from the power supply or the unit itself?
There really shouldn’t be any noise coming from it. It doesn’t have a fan or speakers.
So maybe a bad power supply or capacitor in the device maybe.
Thanks - it’s coming from the unit itself, not the power supply. I’ll see if they can replace it - good to know it should be quiet.
As your S33 is making noise loud, sorry for the inconvenience .
For warranty claim please reach to arris.com/consumersupport
