Wifi password for S33
  • 21 December 2023
  • 129 views
How do I reset my wifi password ?
Best answer by SURFboard Moderator 22 December 2023, 20:16
S33 is just a cable modem without WIFI or inbuilt WIFI on it so to access WIFI you need to connect separate router to the modem and to reset or change the WIFI password please check with the router manual or contact your router manufacturer for guidance.
