Spectrum says this modem cannot be updated I am trying to check if the current software I have is the correct one.
View originalSpectrum says this modem cannot be updated I am trying to check if the current software I have is the correct one.
View originalAre you checking for the firmware update?
There is no option to update the firmware or software manually. Firmware updates will be done only by your service provider and to check the current software version also you need to reach out to your service provider only.
