What WiFi extender goes with sb1690
View originalWhat WiFi extender goes with sb1690
View originalSB6190 is compatible with all brand routers so you can use WIFI extenders only when connected router on this cable modem to extend WIFI signal connect WIFI extenders alone to the SB6190 cable modem will not allow you to access WIFI so please make sure you are connect router to the cable modem then the extenders.
