How to switch router (SB6190) from 5ghz to 2.4ghz?
  • 27 May 2023
  • 253 views
I bought the SB6190 router a couple years ago and it’s been working great. However, I recently moved into a new house that has an outdoor security camera, which requires a 2.4 GHz network. The house is also fairly large, so it might be helpful to switch from 5GHz to 2.4GHz given the improved range.
Thanks in advance!
Ted
Best answer by plemans 27 May 2023, 20:32
Userlevel 6
Badge +40
Not sure what you have but the SB6190 is a modem only device. It has zero router and zero wireless capability. so if you have wireless, its from a different device.
My mistake! All set, I was able to switch off 5GHz on my Eero Pro 6 mesh wifi system temporarily while I set up the camera on the 2.4GHz network.
