Hi,
I have had an Arris Surfboard SB6190 for around 8 years and it has, over the last perhaps year or so, gotten much worse and now, every so often and many times a day, it intermittently disconnects all devices (even a direct cable-connected device) from the internet for between 5 and 60 seconds.
The ISP (Xfinity) says the device communicates with their network with no issues.
When I use the admin interface and check status, using this trouble-shooting link I found (https://arris.my.salesforce-sites.com/consumers/articles/General_FAQs/SB6190-Cable-Signal-Levels), I see that:
- The PDL (Power Download Level?) values are all within the desired range.
- The SNR values are all ok.
- the PUL (Power Upload Level?) values are all ok.
Here is the contents of the Status Page:
Status
The statuses listed show the connection state of the cable modem. They are used by your service provider to evaluate the operation of the cable modem.
Startup Procedure | ||
Procedure | Status | Comment |
Acquire Downstream Channel | Locked | |
Connectivity State | OK | Operational |
Boot State | OK | Operational |
Configuration File | OK | |
Security | Enabled | BPI+ |
DOCSIS Network Access Enabled | Allowed |
Downstream Bonded Channels | ||||||||
Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Corrected | Uncorrectables |
1 | Locked | 256QAM | 16 | 477.00 MHz | 0.90 dBmV | 40.37 dB | 12685 | 12686 |
2 | Locked | 256QAM | 17 | 483.00 MHz | 0.90 dBmV | 40.37 dB | 13022 | 10230 |
3 | Locked | 256QAM | 18 | 489.00 MHz | 0.90 dBmV | 40.37 dB | 11931 | 10774 |
4 | Locked | 256QAM | 19 | 495.00 MHz | 1.00 dBmV | 40.95 dB | 11377 | 12798 |
5 | Locked | 256QAM | 20 | 507.00 MHz | 1.00 dBmV | 37.64 dB | 14896 | 55134 |
6 | Locked | 256QAM | 21 | 513.00 MHz | 1.10 dBmV | 40.37 dB | 11534 | 11446 |
7 | Locked | 256QAM | 22 | 519.00 MHz | 1.10 dBmV | 40.95 dB | 11147 | 10960 |
8 | Locked | 256QAM | 23 | 525.00 MHz | 1.10 dBmV | 40.37 dB | 10727 | 8693 |
9 | Locked | 256QAM | 24 | 531.00 MHz | 1.20 dBmV | 40.37 dB | 10066 | 9765 |
10 | Locked | 256QAM | 25 | 537.00 MHz | 1.00 dBmV | 40.37 dB | 10373 | 10932 |
11 | Locked | 256QAM | 26 | 543.00 MHz | 1.00 dBmV | 40.37 dB | 9413 | 9697 |
12 | Locked | 256QAM | 27 | 549.00 MHz | 0.80 dBmV | 40.95 dB | 9934 | 11599 |
13 | Locked | 256QAM | 28 | 555.00 MHz | 0.70 dBmV | 40.37 dB | 8660 | 8391 |
14 | Locked | 256QAM | 29 | 561.00 MHz | 0.90 dBmV | 40.37 dB | 8967 | 9699 |
15 | Locked | 256QAM | 30 | 567.00 MHz | 1.00 dBmV | 40.37 dB | 8916 | 10912 |
16 | Locked | 256QAM | 31 | 573.00 MHz | 1.00 dBmV | 40.95 dB | 9217 | 10110 |
17 | Locked | 256QAM | 32 | 579.00 MHz | 1.00 dBmV | 40.95 dB | 8694 | 10798 |
18 | Locked | 256QAM | 33 | 585.00 MHz | 0.90 dBmV | 40.37 dB | 7913 | 9499 |
19 | Locked | 256QAM | 34 | 591.00 MHz | 1.20 dBmV | 40.37 dB | 8132 | 8674 |
20 | Locked | 256QAM | 35 | 597.00 MHz | 0.90 dBmV | 38.61 dB | 7524 | 8657 |
21 | Locked | 256QAM | 36 | 603.00 MHz | 0.70 dBmV | 37.64 dB | 10636 | 9688 |
22 | Locked | 256QAM | 37 | 609.00 MHz | 0.80 dBmV | 37.64 dB | 8529 | 10298 |
23 | Locked | 256QAM | 38 | 615.00 MHz | 0.90 dBmV | 38.98 dB | 7947 | 9082 |
24 | Locked | 256QAM | 39 | 621.00 MHz | 0.70 dBmV | 38.98 dB | 8492 | 10344 |
25 | Locked | 256QAM | 40 | 627.00 MHz | 1.00 dBmV | 38.20 dB | 24 | 635 |
26 | Locked | 256QAM | 41 | 633.00 MHz | 1.20 dBmV | 39.20 dB | 13 | 641 |
27 | Locked | 256QAM | 42 | 639.00 MHz | 1.40 dBmV | 39.50 dB | 15 | 638 |
28 | Locked | 256QAM | 43 | 645.00 MHz | 1.60 dBmV | 39.90 dB | 17 | 637 |
29 | Locked | 256QAM | 44 | 651.00 MHz | 1.60 dBmV | 40.40 dB | 16 | 646 |
30 | Locked | 256QAM | 45 | 657.00 MHz | 1.50 dBmV | 40.40 dB | 53 | 580 |
31 | Locked | 256QAM | 46 | 663.00 MHz | 1.60 dBmV | 40.40 dB | 19 | 661 |
32 | Locked | 256QAM | 47 | 669.00 MHz | 1.60 dBmV | 41.10 dB | 872 | 4513 |
Upstream Bonded Channels | ||||||
Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
1 | Locked | ATDMA | 59 | 5120 kSym/s | 29.20 MHz | 49.00 dBmV |
2 | Locked | ATDMA | 60 | 5120 kSym/s | 35.60 MHz | 48.75 dBmV |
3 | Locked | ATDMA | 58 | 5120 kSym/s | 22.80 MHz | 48.25 dBmV |
4 | Locked | ATDMA | 57 | 5120 kSym/s | 16.40 MHz | 49.50 dBmV |
I wanted to verify that I have the latest firmware, but Arris’s site points you to a 3rd-Party, that then points you back to Arris if it is for consumer use. I see no way to get the firmware file’s version or to download any firmware.
Can I get some advice and assistance from the community?
Thanks
