Hello there, can anyone help me interpret my upstream/downstream logs? My internet keeps dropping out with greater and greater frequency it seems. If it’s important, when the internet briefly goes out, the lights on my modem and router remain on/solid. Recently, there are times when it doesn’t connect back automatically and then I have to establish a connection again via my router. I just purchased my router in March of 2021. I received the modem (SB6190) from a friend in 2019 and have had no issues until recently. It looks like the Upstream Bonded Channels are lower than the accepted levels, but I’m not quite sure what that means. I also refreshed the page after 10+ minutes and provided both reports below. For Upstream Bonded Channels on the first report, it shows no readings for channels 1-3. Thanks so much in advance!
Startup Procedure | ||
Procedure | Status | Comment |
Acquire Downstream Channel | Locked | |
Connectivity State | OK | Operational |
Boot State | OK | Operational |
Configuration File | OK | |
Security | Enabled | BPI+ |
DOCSIS Network Access Enabled | Allowed |
Downstream Bonded Channels | ||||||||
Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Corrected | Uncorrectables |
1 | Locked | 256QAM | 37 | 381.00 MHz | 5.10 dBmV | 40.37 dB | 149 | 56 |
2 | Locked | 256QAM | 1 | 783.00 MHz | 2.00 dBmV | 38.61 dB | 84 | 1022 |
3 | Locked | 256QAM | 2 | 789.00 MHz | 1.60 dBmV | 37.64 dB | 104 | 914 |
4 | Locked | 256QAM | 3 | 795.00 MHz | 1.10 dBmV | 38.61 dB | 13 | 34 |
5 | Locked | 256QAM | 4 | 801.00 MHz | 1.50 dBmV | 38.98 dB | 18 | 24 |
6 | Locked | 256QAM | 5 | 807.00 MHz | 1.00 dBmV | 37.64 dB | 13 | 27 |
7 | Locked | 256QAM | 6 | 813.00 MHz | 0.50 dBmV | 38.61 dB | 8 | 30 |
8 | Locked | 256QAM | 7 | 819.00 MHz | 0.90 dBmV | 38.61 dB | 108 | 992 |
9 | Locked | 256QAM | 8 | 825.00 MHz | 0.70 dBmV | 37.64 dB | 11 | 25 |
10 | Locked | 256QAM | 9 | 831.00 MHz | -0.10 dBmV | 37.36 dB | 32 | 50 |
11 | Locked | 256QAM | 10 | 837.00 MHz | 0.20 dBmV | 37.64 dB | 30 | 37 |
12 | Locked | 256QAM | 11 | 843.00 MHz | 0.00 dBmV | 37.64 dB | 26 | 12 |
13 | Locked | 256QAM | 12 | 849.00 MHz | -0.90 dBmV | 37.64 dB | 21 | 25 |
14 | Locked | 256QAM | 13 | 855.00 MHz | -0.50 dBmV | 37.36 dB | 11 | 28 |
15 | Locked | 256QAM | 14 | 861.00 MHz | -0.40 dBmV | 37.36 dB | 22 | 23 |
16 | Locked | 256QAM | 15 | 867.00 MHz | -1.20 dBmV | 37.36 dB | 25 | 16 |
17 | Locked | 256QAM | 16 | 873.00 MHz | -1.00 dBmV | 37.36 dB | 389 | 796 |
18 | Locked | 256QAM | 33 | 357.00 MHz | 4.70 dBmV | 40.95 dB | 143 | 94 |
19 | Locked | 256QAM | 34 | 363.00 MHz | 5.00 dBmV | 40.95 dB | 146 | 83 |
20 | Locked | 256QAM | 35 | 369.00 MHz | 5.00 dBmV | 40.37 dB | 119 | 95 |
21 | Locked | 256QAM | 36 | 375.00 MHz | 4.90 dBmV | 40.37 dB | 130 | 65 |
22 | Locked | 256QAM | 38 | 387.00 MHz | 5.00 dBmV | 40.37 dB | 144 | 40 |
23 | Locked | 256QAM | 39 | 393.00 MHz | 4.70 dBmV | 40.37 dB | 96 | 50 |
24 | Locked | 256QAM | 40 | 399.00 MHz | 4.90 dBmV | 40.37 dB | 59 | 72 |
25 | Locked | 256QAM | 41 | 405.00 MHz | 5.10 dBmV | 39.90 dB | 106 | 75 |
26 | Locked | 256QAM | 42 | 411.00 MHz | 4.90 dBmV | 39.50 dB | 73 | 63 |
27 | Locked | 256QAM | 43 | 417.00 MHz | 4.80 dBmV | 39.90 dB | 88 | 51 |
28 | Locked | 256QAM | 44 | 423.00 MHz | 5.10 dBmV | 39.90 dB | 107 | 58 |
29 | Locked | 256QAM | 45 | 429.00 MHz | 5.00 dBmV | 39.90 dB | 95 | 39 |
30 | Locked | 256QAM | 46 | 435.00 MHz | 5.10 dBmV | 39.50 dB | 139 | 49 |
31 | Locked | 256QAM | 47 | 441.00 MHz | 5.50 dBmV | 39.90 dB | 96 | 26 |
32 | Locked | 256QAM | 48 | 447.00 MHz | 5.30 dBmV | 39.90 dB | 94 | 33 |
Upstream Bonded Channels | ||||||
Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
1 | ---- | ---- | 3 | ---- | 24.00 MHz | ---- |
2 | ---- | ---- | 6 | ---- | 12.80 MHz | ---- |
3 | ---- | ---- | 4 | ---- | 17.60 MHz | ---- |
4 | Locked | ATDMA | 2 | 5120 kSym/s | 30.40 MHz | 45.50 dBmV |
5 | Locked | ATDMA | 1 | 5120 kSym/s | 36.80 MHz | 44.75 dBmV |
Current System Time: Sat Sep 24 00:17:25 2022
1 | Locked | 256QAM | 37 | 381.00 MHz | 4.10 dBmV | 40.37 dB | 574 | 4121 |
2 | Locked | 256QAM | 1 | 783.00 MHz | 1.30 dBmV | 38.61 dB | 293 | 2949 |
3 | Locked | 256QAM | 2 | 789.00 MHz | 0.80 dBmV | 37.64 dB | 366 | 1957 |
4 | Locked | 256QAM | 3 | 795.00 MHz | 0.50 dBmV | 37.64 dB | 131 | 1217 |
5 | Locked | 256QAM | 4 | 801.00 MHz | 0.90 dBmV | 38.98 dB | 499 | 1677 |
6 | Locked | 256QAM | 5 | 807.00 MHz | 0.40 dBmV | 37.36 dB | 258 | 2126 |
7 | Locked | 256QAM | 6 | 813.00 MHz | -0.20 dBmV | 38.61 dB | 223 | 2037 |
8 | Locked | 256QAM | 7 | 819.00 MHz | 0.20 dBmV | 38.26 dB | 204 | 2051 |
9 | Locked | 256QAM | 8 | 825.00 MHz | 0.00 dBmV | 37.36 dB | 141 | 1032 |
10 | Locked | 256QAM | 9 | 831.00 MHz | -0.80 dBmV | 37.36 dB | 222 | 1141 |
11 | Locked | 256QAM | 10 | 837.00 MHz | -0.50 dBmV | 37.64 dB | 437 | 1801 |
12 | Locked | 256QAM | 11 | 843.00 MHz | -0.70 dBmV | 37.64 dB | 163 | 1152 |
13 | Locked | 256QAM | 12 | 849.00 MHz | -1.50 dBmV | 37.36 dB | 38 | 99 |
14 | Locked | 256QAM | 13 | 855.00 MHz | -1.10 dBmV | 37.64 dB | 148 | 998 |
15 | Locked | 256QAM | 14 | 861.00 MHz | -1.10 dBmV | 37.64 dB | 43 | 101 |
16 | Locked | 256QAM | 15 | 867.00 MHz | -1.90 dBmV | 37.09 dB | 186 | 2059 |
17 | Locked | 256QAM | 16 | 873.00 MHz | -1.60 dBmV | 37.36 dB | 609 | 2957 |
18 | Locked | 256QAM | 33 | 357.00 MHz | 3.80 dBmV | 40.95 dB | 547 | 4300 |
19 | Locked | 256QAM | 34 | 363.00 MHz | 4.10 dBmV | 40.37 dB | 458 | 4286 |
20 | Locked | 256QAM | 35 | 369.00 MHz | 4.00 dBmV | 40.37 dB | 634 | 3989 |
21 | Locked | 256QAM | 36 | 375.00 MHz | 3.90 dBmV | 40.37 dB | 588 | 4005 |
22 | Locked | 256QAM | 38 | 387.00 MHz | 4.00 dBmV | 40.95 dB | 507 | 3130 |
23 | Locked | 256QAM | 39 | 393.00 MHz | 3.70 dBmV | 40.37 dB | 672 | 3737 |
24 | Locked | 256QAM | 40 | 399.00 MHz | 3.90 dBmV | 40.37 dB | 420 | 4014 |
25 | Locked | 256QAM | 41 | 405.00 MHz | 4.10 dBmV | 39.90 dB | 152 | 674 |
26 | Locked | 256QAM | 42 | 411.00 MHz | 3.90 dBmV | 39.50 dB | 90 | 693 |
27 | Locked | 256QAM | 43 | 417.00 MHz | 3.80 dBmV | 39.50 dB | 107 | 676 |
28 | Locked | 256QAM | 44 | 423.00 MHz | 4.10 dBmV | 39.90 dB | 123 | 685 |
29 | Locked | 256QAM | 45 | 429.00 MHz | 4.00 dBmV | 39.90 dB | 139 | 639 |
30 | Locked | 256QAM | 46 | 435.00 MHz | 4.10 dBmV | 39.50 dB | 151 | 681 |
31 | Locked | 256QAM | 47 | 441.00 MHz | 4.50 dBmV | 39.90 dB | 109 | 655 |
32 | Locked | 256QAM | 48 | 447.00 MHz | 4.30 dBmV | 39.90 dB | 108 | 661 |
1 | Locked | ATDMA | 3 | 5120 kSym/s | 24.00 MHz | 35.25 dBmV |
2 | Locked | ATDMA | 6 | 2560 kSym/s | 12.80 MHz | 36.50 dBmV |
3 | Locked | ATDMA | 4 | 5120 kSym/s | 17.60 MHz | 36.00 dBmV |
4 | Locked | ATDMA | 2 | 5120 kSym/s | 30.40 MHz | 37.00 dBmV |
5 | Locked | ATDMA | 1 | 5120 kSym/s | 36.80 MHz | 37.50 dBmV |
Current System Time: Sat Sep 24 00:29:47 2022
