Hello
My Arris Wi-Fi router is working fine. However, I’d like to use the Ethernet ports on 2 devices for hardwire connections. In the past, I did not have any issues with hardwire but for some reason(s) I cannot get a hardwire connection for my Fire Stick and Max Free Streaming TV box. I did not have this issue before.
I’m using an Amazon adapter for the Fire Stick which worked before. But when I check the Fire Stick Network, it shows I’m connected only to my home Wi-Fi and not as a hard-wired connection.
I’ve also noticed there is no Ethernet Cable on the Arris router. Should there be one?
I’m using a CAT8 ethernet cable on both devices. Wondering if the CAT9 cable is compatible with the devices.
Do you recommend I reset the Arris Router?
I would appreciate it if you could provide me with some information and suggestions to get this matter resolved.
Thank you so much.
P/N: SBG00DA76950B
