Recently, I’ve noticed I lose connectivity to Xfinity for short periods of time. To try and narrow down the point of failure, I set up continuous IPv4 pings to google.com, the first hop in a tracert to the internet, and my local gateway (192.168.0.1).
When the issue occurs, I first see dropped pings to google and the tracert first hop. After a few dropped packets, I see drops to my local gateway as well. The loss of packets to the local gateway surprised me but I’m speculating the Arris SBG6950AC2 modem may be reacquiring its IP config when the connectivity drops.
The Xfinity bot doesn’t detect an issue on their end. Signal levels seem reasonable based on what they were when I first got the service. The Arris log shows RCS Partial Service, SYNC Timing Synchronization failure - Loss of Sync, and Lost MDD Timeout errors.
I own the modem and was intending to update the firmware if necessary but discovered on this forum that the ISP is responsible for maintaining the firmware on the device and I don’t even have the capability to update it.
Any suggestions to help stabilize the connection would be appreciated.
