it set on 10 hours and 00 minutes. Not sure if its a timer or what it is
View originalit set on 10 hours and 00 minutes. Not sure if its a timer or what it is
View originalAre you referring to the modem GUI page where it will ask you to set the Time of your location on the initial setup of your modem?
Product Runtime is only for factory use. There is no impact on operability.
