DNS Override not working for SBG7400AC2
  • 6 September 2023
  • 21 views
Hi there,
So I’m trying to make use of the DNS Override feature in LAN settings, and even after hitting apply, the router isn’t able to block websites. What’s the issue?
Best answer by plemans 7 September 2023, 19:48
Userlevel 6
Badge +40
Not sure exactly what  your attempting as this was pretty brief. Sounds like you’re trying to do website blocking. One of the problem could be that most websites use https
“s” is an encryption between computer/website. So if you’re doing website blocking, the standard blocking features don’t work if its a encrypted link.
