How to connect printer in G34
  • 9 January 2024
  • 155 views
I cannot find a way to connect my printer it says that I have to add the MAC address to the router to accept it but I can not find where to do that, I see no where to add a device with in the surfboard hub.
Best answer by SURFboard Moderator 13 January 2024, 02:08
Could you please help us with the printer model number so that we can check and help you with the steps to connect to modem WIFI network.
It is a HP 5530
Since you are trying to connect the printer with this model G34, I suggest you change the security mode in 2.4Ghz.
Let me help you with the steps.
Launch the web browser>enter it in the address box as 192.168.0.1>login.
Gateway>summary>connection>Wi-Fi>networks>edit.
Then select security mode as WPAWPA2-PSK(TKIP/AES).
After changing the security mode, power cycle the printer once and connect with 2.4ghz Wi-Fi network.
TY TY! I am connected my work will
love me again 🎉🥳
