How do I get this modems Ethernet port to operate at it’s rated speed of 1Gbps?
I didn’t see any configuration setting for this when I logged into it.
Or is this SB6190 only capable of 100Mbps on the port?
Best answer by LoveMyLab
View originalHow do I get this modems Ethernet port to operate at it’s rated speed of 1Gbps?
View originalYou shouldn’t to change it’s configuration, but there are many factors at play here.
With a little more data, hopefully we can identify the real root cause here.
The SB6190 is connected directly to a security appliance.
I swapped the nic on the appliance and it’s back to what it should be (ethtool eth0)
Thanks.
