I have had an Arris Surfboard sbg7600ac2 for about the last 3 years, everything has been working fine until this morning.
My connection kept dropping out on my connected devices and when I would go check the router, all the lights were off except power.
It would restart and bring all lights back on, and all devices would connect then after a couple minutes it would turn off again and the modem would drop back to just the power light, then restart again. Over and over.
I've unplugged the modem for several minutes then turned back on, same problem. I've reset the modem to factory settings, it works for a little longer then same problem.
Running firmware 9.2.103AA85
Any help would be appreciated.
