Arris TG862G modem
  • December 21, 2022
  • 276 views
I lost my username to be able to log into my router so I can change the network password. I see that my modem isn’t supported any longer. I know it has been changed from the default, and I’m on my last attempt before I get locked out. Help!
Best answer by Netopia
Sounds like you forgot your login password.  I suggest factory resetting the TG862G as the last resort so that you can login with the default password to change your network password.
Forum|alt.badge.img+30
  • Rockstar!
  • 274 replies
  • December 21, 2022
  • December 21, 2022
Resolved, thank you. No help from Arris at all because the modem is “no longer supported.”
