I lost my username to be able to log into my router so I can change the network password. I see that my modem isn’t supported any longer. I know it has been changed from the default, and I’m on my last attempt before I get locked out. Help!
Arris TG862G modem
Best answer by Anonymous
Sounds like you forgot your login password. I suggest factory resetting the TG862G as the last resort so that you can login with the default password to change your network password.
