TG2762G
I have a TG2762G that provides cable, telephone and only marginal WiFi. I bought a mesh router/WiFi to improve things. It wants me to turn off the TG2762G’s router/WiFi functions. I don’t how to do this.Can someone help do this?
are you sure thats your model number? google literally has 2 posts for that number and this post is one of them
  • 2292 replies
  • July 9, 2023
  • July 9, 2023
You are right. We double checked our cable modem, the correct number is TG2472.
  • October 30, 2023
Security is low how do you fix this.
