Upgrade Arris DG1670 to newer model
  • August 22, 2024
  • 159 views
I am using Sparklight and considering stopping the lease on their Arris DG1670. This is an old modem/router. Any recommendations for a newer model. the speed I am using is up to 300 GPS. I would need the WIFI to be 2.4 GHz N + 5 GHz AX.
If I continue my lease with Sparklight they would provide a  Hitron Coda 57. I have not had experience with the HItron. Any thoughts?
Any feedback would be appreciated.
here’s their approved list. They tend to be outdated though.
https://support.sparklight.com/hc/en-us/articles/115009158227-Supported-Modems-Residential-Only
  • August 23, 2024
You can look at sparklight’s approved list. I think the G34/G36 are on there. Not sure if they support the G54 if you’re interested in wifi 7
  • August 23, 2024
  • August 24, 2024
Problem solved. Thank you for your valuable suggestions. The Sparklight repairman came to my house and we discussed my options.
