Alexa skils
  • May 26, 2022
  • 57 views
Where the Wild Pings Are
Cable Modem Commandos
Forum|alt.badge.img+9
What skills can I use with my Alexa?
Best answer by TechRep
Hello
First you need to enable Alexa features and link your device. Once that is done these are the skills you can use:
Alexa, Ask SURFboard for HelpA
Alexa, Ask SURFboard for my Guest Wi-Fi password
Alexa, Ask SURFboard to enable my Guest Wi-Fi network
Alexa, Ask SURFboard to disable my Guest Wi-Fi network
Alexa, Ask SURFboard to check my Wi-Fi network
Alexa, Ask SURFboard to restart my gateway
For help to enable and link refer to:
http://arris.force.com/consumers/articles/General_FAQs/mAX-WC4T-Amazon-Alexa-Skills-Setup
https://arris.secure.force.com/consumers/articles/General_FAQs/SBG8300-Amazon-Alexa-Skills-Setup
http://arris.force.com/consumers/articles/General_FAQs/mAX-Routers-Amazon-Alexa-Skills-Setup
TechRep
  • Cable Modem Commandos
  • 45 replies
  • May 31, 2022
Hello
