How do you configure parental control feature?
  • September 24, 2021
  • 253 views
mAX SURF
The Certified
I need help understanding how to configure the parental control feature
Best answer by Manoj Thirumalai
Using SBC app (Please refer to the below link)
Step 1: Select “parental control “
Step 2 :Create profile
step 3 :Add device
https://arris.secure.force.com/consumers/articles/General_FAQs/mAX-Routers-Parental-Control-Setup#User
TechRep
Cable Modem Commandos
Forum|alt.badge.img+9
  • Cable Modem Commandos
  • May 27, 2022
This will depends on ARRIS device you have and also if you are using the app to manage your network. If you reply to me with the model number of the ARRIS unit I can show how to configure it or you can type the model of the unit next to words parental control on Google and you will get the instructions.
Manoj Thirumalai
The Many
step 3 :Add device
